Xuelin Ihifi960 |
Xuelin Ihifi960 |
21.11.2013, 21:43
Активный участник Группа: Пользователи Сообщений: 30 Регистрация: 30.4.2010 Пользователь №: 516 |
Решил сделать несколько необычное описание, было интересно, что получится.
И в конце инфа в виде текста: Descriptions: Ihifi960 is based on ihifi812 from years of research and development .This equipment had joined the rare coaxial / optical fiber output (optical fiber connection can achieve electrical isolation to prevent digital noise transmitted through the ground, so that the signal is more pure), the product can not only carry, more cross-border acts as a pure digital turntable / desktop CD role, providing high-quality end-to-end digital audio, not less than the effect of a high-end CD. Flexible file management is better than desktop CD. While it commendable remains 12 hours of battery life, while 30% smaller. Filtering use solid state capacitor and polymer capacitor combination,that make power purity reached a new height, making a foundation for the voice of details and reducing the background noise music. pure sweet sound, dark background, has a simulation feel. Frameworks: Audio coupling: top MUSE KZ series ( two ) Filter: Sanyo solid polymer capacitor LPF: Panasonic capacitor SMD film ( 5%, not ordinary soldering ) Amp: ad8397ardz rail-to-rail amplifier Decoding: wm8740 (single ) Lpf: lme49720 THD 0.00003% Src:ad1896 The local clock: 0.5PPM ( Phase noise-125dBc/1KHz ) tcox temperature compensation crystal 11.2896mhz Power supply: ultra low ripple ( 1mV ) double inductor topologies of DC power supply Pcb board: 4 layer 2 times on Cu + electromagnetic shielding cover Interface: 1.Coaxial RCA coaxial digital output interface ( IEC-60958 ) 2. optical fiber Optical output interface ( round ) 3. LINE OUT line output (share with fiber export ) 4. HEADPHONE 3.5mm headphone output interface (a 6.5mm headphones conversion head, can easily drive 16-300ohm. ) 5. 12V power charging interface 6. usb data interface 7. tf card interface ( please use class4 Kingston TF Card ) 8. analog potentiometer volume adjustment Technical Parameters: Headphone output power: 450mw/16ohm220mw/32ohm50mw/300ohm Coaxial output impedance: 75Ohm Coaxial output level: 500mv P-P Line output reference level: 2V ±1.8dB ( 1KHz ) SNR:≥ 109 dB ( A weight ) Channel balance:≤ 1.5dB ( 1KHz ) The degree of channel separation:≥ 95dB ( 1KHz ) frequency response: 20Hz ~20KHz ( +0/-2.5dB ) Total harmonic distortion plus noise: ( 1KHz≤ 0.003% ) Life time: wav format for about 12 hours ( display closed) ape format for about 10 hours ( display off) fiber output state is reduced about 5% Support audio formats: WAVAPE FLACAAC OGG MP3 WMA ( 8-48k ) Storage capacity: built-in 16GB extension 0-32GB Battery: 1200mAh 7.4v lithium battery Net volume: 110*70*26mm Net weight: 301g -------------------- Плеер: IHIFI 960
Наушники: HiSoundAudio PAA-1\ HiSoundAudio PAA-1 PRO\ HiSoundAudio Live\ MYST Nail 2 ------------------------------------------- плеер: Creative X-fi Fatal1ty \ Вега 122с усилитель: Вега 10у-120с \ Radiotehnika У 7111 наушники: Fostex T50RP \ ТДС-5М колонки: Radiotehnika 35 АС-201 \ S-30 были: наушники Sennheiser PMX60, Sennheiser HD525, Grado iGrado плеер: HiSoundAudio RoCoo D |
20.2.2014, 12:26
А вот промеры iHiFi960
И, если мне не изменяет память на промеры разных аппаратов, среди дельта сигм мы имеем лидера. Интермоды 110-115дб. Шумы -120. Гармоники 100. АЧХ неравномерность 0.18дб. Блин нам серьезно придется постараться чтоб свой сделать такого же уровня. Одно утешает - оставили лазейку в переходной - завальчик виден. Есть куда расти. http://ozvuke.pro/index.php?showtopic=1572 P.S. Есть (мной лично) не проверенная информация, что этот (а так же и 960тый) аппарат при подключении к усб для заливки контента, начинает достаточно активно разряжаться. Видать большая ёмкость батареи (все-таки 18часов работы! типа) заставила применить более агрессивные схемы заряда и типовой усб компа для них слабоват и уже плеер начинает отдавать энергию. -------------------- |
23.3.2014, 20:55
Удивительно. Честно говоря, басы мне кажутся на нём какие-то невнятные, и будто есть всплески на атаках. Удивился, что измеритель вообще их не показал. (хотя это возможно особенность слуха). Наушники Nail2.
При замере, настройка эквалайзера была на "нормально"? -------------------- Плеер: IHIFI 960
24.3.2014, 10:52
почему это не показал???? Смотрте график переходной - у любой дельты есть всплески на атаках. К тому же он неплох для дельты, но все равно не идеален. Насчет невнятности, недостатка скорости и агрессии - так этим вольфсон всегда грешил.
эквалайзер был выключен. -------------------- |
24.3.2014, 10:54
Погодите ка, у него нельзя полностью отключить эквалайзер. Можно только выставить "нормально" или что-то еще.
А много времени занимает снятие ачх? -------------------- Плеер: IHIFI 960
24.3.2014, 10:57
само снятие - немного. подготовка чего-то занимает.
Отключение эквалайзера - имею в виду что он не учавствовал в измерениях. В общем как-то так. -------------------- |
24.3.2014, 11:01
Я не очень понял график "График прямоугольного сигнала частотой 100 Гц" у него почему-то всплески не на атаке, а на начале спада. Или я не так на него смотрю?
А последний график "График фронта выходного сигнала прямоугольной формы частотой 100 Гц. Завал и искажения в виде переходного процесса отсутствуют" так и вообще как-будто идеальный? -------------------- Плеер: IHIFI 960
24.3.2014, 11:19
ДА - на выходе всплески даже больше. Кстати - этои может быть причиной отмеченной вами мягкости и неоформленности. Всплески есть и в начале - в том числе и на графике переходного сигнала это видно, просто они меньше по уровню.
Насчет подписи в конце - да - там нет завала (полочка "параллельна "полу""), и особых искажений. НО никто не отменял и наклон вертикальной составляющей и волны по горизонталям. "Идеальный" он только с точки зрения что у дельты по другому и быть не может. Ну примерно как запорожец завелся и поехал - значит он идеален, потому, как от него больше ждать нечего. Но он не спортивный ауди - его уровень всего-лишь на уровне запорожца. Так и тут - для дельты очень неплохо. Искажения в пределах нормы, и дают некий окрас. За свои деньги, в таких размерах и на вольфе, с подобными ДД и С/Ш - аппарат прекрасен. Но в тот же самый момент НМ601 принципиально лучше его по переходной при меньшей цене. И 960 не станет никодга в жизни таким как 601, потому что 601 мультибит без ЦФ, а 960 - дельта. -------------------- |
24.3.2014, 11:33
А какие тогда могут быть преимущества у 960 перед 601, если 601 лучше звучит, меньше стоит, меньше весит и меньше занимает места? Ведь единственное назначение этих "гробов за безумные деньги" хорошо звучать. А что такое ДД и С\Ш и без ЦФ.
24.3.2014, 12:10
У каждого свои понятия о преимуществах. Для меня никаких, для другого - наоборот.
ДД - динамичесвкий диапазон С/Ш - сигнал/шум ЦФ - цифровой фильтр. -------------------- |
24.3.2014, 12:47
Вот кстати встроенными пресетами эквалайзера удалось несколько исправить ситуацию. Поставил режим "джаз" вместо "нормально". Гудение на низких, которое заполняло весь "фон" ушло полностью, даже кажется, что всплески на атаках стали чуть меньше. В общем, уши не устают так, как раньше. Низы более выраженные стали. Но "солист" отдалился, звучание как будто стало несколько уже. В общем, я понял, что это проблема Вольфсона, а не настроек. )
9.8.2014, 13:31
Достаточно долго я игнорил сей аппарат в плане написания небольшого обзора. Хотя слушал не раз, но вот до клавиш пальцы не добирались.
Да и по промерам уже даже пробирались Постараюсь быть краток. Сразу что хотел отметить, что у "старичка", все-таки хороший плотный низ. Неплохая плотность баса и его удара, хорошие атаки, В общей манере звучать практически отсутствует легковестность обычно присущая вольфу в плеерах... хотя вообще говоря высокие будто бы чуть задраны, или выделены и временами ощущение легкости и яркости есть, но не переходящее в серьезные искажение и гиперокрас. Иногда это вызывает ощущение какого-то смешения информации на вч, эдакой легкой кашеобразности если мелодия сильно уж звенит и шуршит на вч всякими тарелками и чем там еще. Так же бывает ощущение крикливости, но не очень сильное, скорее как приятный подкрас. В общем существенно настроение музыки вроде как не меняет. Хотя - кому как. Средниче частоты вполне прозрачны и чисты. Низами не вуалируются, по уровню вроде никуда не проваливаются и не лезут. Хотя есть ощущение что на них акцент. Светлый такой, ясный, прозрачный и "веселый" акцент.. В остальном писать нечего - на средних как правило в хорошей технике проблем минимально и тут много не напишешь. Заметил странность поведения при перемотке на следующий трек. Очень сильно напомнило Aune - при нажатии "следующий трек" - аппарат выдает короткие шумы очень напоминающие царапание иголки по пластинке. Ну или просто какой-то скользящий скрип-шипение. Так же не очень понял почему -------------------- |
Текстовая версия | Сейчас: 25.4.2024, 8:31 |
